hey guys i normally am in to big block chevelles and parts for them but i came across a motor that i hope maybe you guys can decifer. Its a 1968 block 3914678 heads are 3890462 and intake is 3919803. I dont have many books about small blocks but the one i have says that this could possibly be a corvette 327 or camaro 302. besides checking the crank numbers is there anyway to know. Any input is greatly appreciated.thanks.
Block is listed as being '68; 302 / 327 /350.
Heads are listed as same engines ;'66-'67, 64 cc
Manifold ;
#3919803 67-68. 327,350. Qjet 250,275,325,350Hp
Does the block still have the factory code (2 letters ) stamped on the pad front of pass head?
If so may identify from here
