Remote oil filter
Old Oct 11, 2005 | 01:43 AM
Performance nut's Avatar
Performance nut
Default Remote oil filter
What is needed to relocate the oil filter remotely?
One of these:
http://www.jegs.com/webapp/wcs/stor...10467&langId=-1
Some -10 SS braided hose and fittings
Oil filter
What else?
Old Oct 11, 2005 | 10:08 AM
gkull's Avatar
gkull
I couldn't pull up the site you listed. But anyway I used to have a car with twin remote oil filters. I did it mainly for additional volume and cooling.
My setup also had some kind of thermal bypass in the adapter plate.
To answer your question. The kit I bought was complete with so many feet of SS hose. I just put electrical tape around where I needed to cut and used my air wheel cutter. Those A/N ends are pretty easy to custom install. This wasn't a vette, but I put the filters where I had good access up front of the radiator. Lot's of room on 66 Impalas
Old Oct 11, 2005 | 01:51 PM
comp's Avatar
comp
had a set-up like that on my off-road Baja can't remember the brand right now
Old Oct 11, 2005 | 05:21 PM
Performance nut
http://www.jegs.com/webapp/wcs/store...0467&langId=-1
If the link still doesnt work, its a Moroso remote oil filter mount.
Old Oct 11, 2005 | 05:26 PM
comp's Avatar
comp
mine had the fittings on the same side,, line to it and back easier to run
To Remote oil filter
