oil pump drive system question..
Old Oct 23, 2005 | 10:55 AM
lcvette's Avatar
lcvette
Default oil pump drive system question..
I am converting an LTx block to use a distributor, It came to my attention that there may need to be a bushing in the block where the oil pump driveshaft goes through. can anyone verify this? thanks in advance!
Chris
Old Oct 27, 2005 | 02:32 AM
rodj's Avatar
rodj
The dist mounts in a the hole in the intake and another at the bottom of the lifter valley.
The only thing the pump drive touches is the dist gear at the top and the pump shaft itself where the plastic retainer holds it.
Spining in free air otherwise.
Old Oct 27, 2005 | 10:36 AM
CFI-EFI's Avatar
CFI-EFI
That is certainly the set up in the Gen I engines.
RACE ON!!!
Old Oct 27, 2005 | 09:44 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Only spend about $7-8 for a Melling hardened shaft w/ steel coupler instead of the plastic POS. Or get the Moroso or ARP versions for under $15.
To oil pump drive system question..
