4"+ SBC stroker question
Old Nov 30, 2005 | 09:46 PM
danno85's Avatar
danno85
Default 4"+ SBC stroker question
So all you guys running a 4" stroke crank or better in a small block, what oil pan are you using in the Corvette? Did the rods clear without modifying? What's the depth? Brand and part number would be great.
Thanks!
Dan
Old Dec 1, 2005 | 06:50 PM
korvetkeith's Avatar
korvetkeith
You buildin one danno? I doubt anyone will have a suggestion for you, they don't even think its possible!
Old Dec 2, 2005 | 10:32 AM
CFI-EFI's Avatar
CFI-EFI
Mine has a Canton pan.
RACE ON!!!
Old Dec 2, 2005 | 02:23 PM
gkull's Avatar
gkull
I have the Morroso 8 quart made for 4 inch stroker stock block SBC.
The reason I didn't mention it is because it was not a Vette friendly item. I had to space the steering ram lower on my 79 to clear the deeper front oil pan. It's also 8 or 8.5 deep in the back. That's not really a big deal because my Hooker SC collector flanges are actually lower.
The ++++ of this pan is adjustable crank scraper and baffles. I have never had the oil pressure even fluctuate even in extended road racing track high "G" turns.
Old Dec 3, 2005 | 09:47 PM
danno85's Avatar
danno85
Thanks for all the replies.
korvetkeith - yep, I am
CFI-EFI - are you running the Canton road race pan they make specifically for the 84-96 Corvette? How do you like it? Are you running a 3.8" or longer stroke crank?
gkull - I appreciate the input. I'll be running mine in a C4. The factory C4 pan is 7" deep and I'm already running a 7.5" deep pan. I haven't had any problem with ground clearance, but it does hang down a little lower than my headers, so I'm reluctant to go 8" deep. But I looked at a Moroso pan that is probably what you're running and I like the idea of a deeper front section and the full length scraper. Hamburger makes a nice looking stroker pan also that has a deeper front, but it's also 8" deep at the sump. I'm just trying to figure out what all the options are out there. BTW - what heads are you running on your 427 Motown?
Dan
Old Dec 4, 2005 | 11:05 AM
gkull's Avatar
gkull
Dan
Dart Pro1 227cc CNC
Here is that Morroso pan
Old Dec 4, 2005 | 11:31 AM
CFI-EFI's Avatar
CFI-EFI
Dan
I am not actually "running" it. It came with a new, never fired, engine I bought. He had installed it in his C4, and he apologized for the scraped up decals on the pan. Apparently it is tight, but it fits. I tore the engine down to see if it would pass muster, and I haven't reassembled it yet. It has a 4.00" stroke.
RACE ON!!!
To 4"+ SBC stroker question
