Exhaust manifold gaskets? do you need them?
Old Dec 7, 2005 | 10:57 PM
NASCAR314's Avatar
NASCAR314
Default Exhaust manifold gaskets? do you need them?
On an Iron headed motor using cast iron exhaust manifolds, do you need to use gaskets?
If you have the manifolds "planned" (milled flat), is it neccessary to use those ugly exhaust manifold gaskets?
Anybody running a set-up with no gaskets on exhaust manifolds?
My motor in question is a Big Block w/ iron heads, manifolds are currently off the car, getting Jet-Hot coated.
Old Dec 7, 2005 | 11:10 PM
Monty's Avatar
Monty
It'll be noisy if you don't, you'll end up with small exhaust leaks that sound like ticking noises, very similar to noisy lifters. Even if the manifolds and/or head mating surface is milled flat, it'll still leak and make noise eventually.
Old Dec 7, 2005 | 11:22 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Some V8s used to come from the factory that way, not sure if the BBC was one of them. But I've put BBC manifolds on w/o gaskets after resurfacing them and don't recall ever having any problems or leaks.
Old Dec 8, 2005 | 12:56 PM
GOSFAST's Avatar
GOSFAST
Default Exhaust Gaskets
Freshly restored (100%) Chevelle 1972 LS-5, no gaskets from G.M. And no leaks also. Thanks, Gary in N.Y.
Old Dec 8, 2005 | 08:29 PM
Entropy's Avatar
Entropy
St. Jude Donor '08-'09
I've always used them...kind of like cheap insurance. I hate playing with exhaust, and for the small price they command (less then $10 for fel pro from my local parts store) I don't see any reason not to use them. They've never caused any leaks for me.
trw
Old Dec 14, 2005 | 12:24 PM
632C2's Avatar
632C2
I would start out without any gaskets. If any leaks developed it would be easy enough to add a set.
The last couple of motors I've run with exhaust manifolds have not had any gaskets and no leaks.
Steve
Old Dec 14, 2005 | 12:51 PM
johnfharding's Avatar
johnfharding
Default No Gaskets on my 327 350hp
I haven't noticed any leaks,, thanks,, my 94 chevy pickup didn't have any when I switched to headers,, it didn't have any leaks,,, heck ,, most of the stock manifolds I have seen don't have gaskets if they are cast iron that is.
Old Jan 7, 2006 | 11:11 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
No.
No.
Yes.
To Exhaust manifold gaskets? do you need them?
