Any induction experts here?
Old Jan 8, 2006 | 12:47 AM
AZDoug's Avatar
AZDoug
C1 of Year Finalist (performance mods) 2019
2017 C1 of Year Finalist
Default Any induction experts here?
Trying to firm up a cold air intake system on my EFI '61.
I have a 1000 CFM throttle body mounted atop a Victor Jr manifold. There is 3.8" surface to surface clearance between the top of the throttle body, and the bottom of the hood, so I figure about 3.5" is as far as I want to go, height wise above the T-body.
I will be using the original 4.5" FI fresh air inlet at the rad support, and figured on taking a 4.5" flex hose back to a custom air cleaner box mounted about where the original FI air cleaner went. I can fit a 110 square inch aircleaner in an aircjeaner box at that location w/o problem.
Now for the harder part:
Does anybody make plenums that will fit on the T-body (5.12" diameter) that will handle my required 650 CFM without more than an inch or so of H2O pressure drop restiction?
Is a 4" aluminum tube/w rubber adaptor pieces from the outlet of the aircleaner box to teh T-body plenum adequate for this airflow, assuming two 45 degree angle bends?
What sort of turbulance issues, if any, will I run into with a side fed plenum, as compared to how a regular 360 degree air cleaner feed a T-body?
Any other suggestions?
Thanks,
Doug
Old Jan 8, 2006 | 04:32 PM
71coupe's Avatar
71coupe
Procharger sell this hat for their blower systems, might work with your setup
What brand EFI are you using?
Old Jan 8, 2006 | 07:23 PM
AZDoug's Avatar
AZDoug
been scoping the Pro Charger hat. it has a 3.5" intake. Absolutely fine for the boost they run, and probably fine for me.
The four barrel throttle body I have has 9.62 sq-in of throttle plate (rated 1000 CFM). the 3.5" Pro-charger hat has about about 8.3 sq-in of inlet area.
Maybe need something a bit larger, IF I need it? Do I need to stay same size inlet area on the intake tube as the throttle plates, or will my 650 CFM flow OK with minimal loss thru a 3.5" OD tube?
EFI is a custom setup using a MEFI-4b ECU, on a Victor Jr manifold.
Thanks,
Doug
Old Jan 9, 2006 | 12:48 AM
71coupe's Avatar
71coupe
I'd get with the company you got your custom EFI setup with and ask them about what size inlet to run. I think Paxton and Vortech also sell a blow thru kit, but it might be too tall.
Old Jan 9, 2006 | 01:10 AM
AZDoug's Avatar
AZDoug
Most of their applications are large open aircleaner for racing, with some induction setups but the induction setups I have seen, seem more for show with all the mirror polished tubing, etc. Not sure how much science went into the choices and sizing, as they tell me: "We have used 3.5" up to 383 and it seemed OK". That isn't science.
I have found a LOT of material on exhaust; flowrates vs pipe size, collector lengths, resonator boxes, etc, but next to nothing on the intake side WRT to actually engineering a system, rather than hanging a bunch of parts on and hoping it was better than the last set of parts.
Doug
To Any induction experts here?
