DFI
Old Aug 5, 2001 | 11:36 AM
John Mattiace's Avatar
John Mattiace
Default DFI
Im running a 383 with a Super ram, Trick flow 23 degree heads, a mild hydraulic
cam, and lots of other goodies. My question is Injector sizing i suspect the current 30
pounders are to big. (DFI cannot compensate?) I can drop fuel pressure from 50 to
42 pounds with no change in performance or fuel economy. I tried this in open and
closed loop no difference. Changing numbers in the fuel map doesn't seem to have
much effect. Thanks for any info in advance!! :confused:
Old Aug 5, 2001 | 01:17 PM
Doug Flynn's Avatar
Doug Flynn
Default Re: DFI (John Mattiace)
John,
Please be more specific. I have run 30's in small blocks all the time with no problems. What is your pulse width at hot idle in neutral (in milliseconds)? What is the closed loop correction telling you (is it always trying to pull out fuel)?
Did you just switch to DFI or the 30's?
Doug :chevy (I just felt like trying that thing!)
Old Aug 6, 2001 | 12:06 AM
John Mattiace
Default Re: DFI (Doug Flynn)
Pulse with reads 2.56 on average o2 reads 6.50-6.70 this is a hot idle in neutral. I
have the timing set at 36 total there is no ping that i can hear at full throttle. :smash:
Old Aug 6, 2001 | 10:03 PM
Doug Flynn's Avatar
Doug Flynn
2.5 ms sounds a little high. I'd expect it to be around 2.0-2.1. Have you really tuned the entire map or are you just getting started?
Old Aug 7, 2001 | 05:43 PM
John Mattiace
The car runs great my problem is at full throttle and fuel economy.
The air ratio meter reads about 13.5 at steady speed's (off idle to about 50 mph)
this would very light on the throttle. No matter what i do to try and lean things out
it always runs rich. On full throttle it just berries the meter. I have tried making my
own map
i get the same results. If you happen to have the February 2001 Hot Rod issue they
featured a 350 (415 hp) i copied this motor. The only difference is i built a
383/10.01.
Some other things i have are Supper Ram,58mm throttle body, edelbrock headers,
big mouth lower, regulator, Holy 255 pump, 1.6 rockers, And a bunch of other
stuff.
Thanks in advance
Old Aug 9, 2001 | 03:05 AM
C4RACER's Avatar
C4RACER
At WOT the O2 sensor is quite confused. Don't worry about the bar graph at WOT. The only way to really dial in O2 is on a chassis dyno with a wideband O2 sensor. You want to shoot for ~12:1 through most of the the RPM range. You can also check plugs and MPH at the drag strip just like w/ a carb.
All this really points to the beauty of the new DFI w/ wideband O2 capability, don't it?
Scott
Old Aug 14, 2001 | 05:57 PM
John Mattiace
Default Re: DFI (C4RACER)
Thanks for your help. I think its time for a carb. :confused:
To DFI
