Fast Burn Heads
Old Aug 9, 2001 | 02:48 AM
C4RACER's Avatar
C4RACER
Default Fast Burn Heads
Has anyone tried the fast burn heads with a normal intake manifold? One of the guys over at Skiggins Dickey told someone you can run a normal intake with the fast burn heads and it's close enough that it works. The intake in question was the Edelbrock Pro-flo. It's in a car I'm considering buying, so any feedback would be very helpful!!
Scott
Old Aug 19, 2001 | 11:04 PM
81ZZ4's Avatar
81ZZ4
Default Re: Fast Burn Heads (C4RACER)
From what I have learned the FastBurns have a Raised runner.
Call Edelbrock to be sure but I think you will have a mismatch on the ports.
There are specific intakes that work with the FastBurns to take advantage of the raised runners.
