looking for a blow-through carb configuration for my 73' thats going to have a large single turbo on it. anyone have a place that sells kits to convert em' over or a site that has what to modify on/in the carb to accept boost pressures?
Carb is currently a Holley 950hp mechanical an its unmodified out of the box
if you have an O2 sensor hooked up, I would try the carb you
already have. I think the main things are the black floats,
and the boost referenced fuel pressure regulator.
I have never used this setup but from what I hear its not too difficult
If you check out Turbomustangs.com forums there is a ton of information about building blow thru carbs. also this is a nice step by step guide for modding a double pumper. Blowthru cab mod
