Piston Dome Volume??
Old Feb 14, 2006 | 08:21 AM
61driver's Avatar
61driver
Default Piston Dome Volume??
Please correct me if I am wrong, but a flat top piston with valve reliefs would have a - (minus) dome volume when used for compression ratio calculations. The technician I talked to only confused the math even more. thanks in advance..
Ray
Old Feb 14, 2006 | 09:55 AM
CFI-EFI's Avatar
CFI-EFI
Bassackwards. A dome reduces the ccs of the combustion chamber, so the dome volume is subtracted (-). A valve notch is a volume to be added (+).
RACE ON!!!
Old Feb 14, 2006 | 11:59 AM
SWCDuke's Avatar
SWCDuke
Yes, and the piston mfg. should have the specs. For example, the flat top, four notch OE 327 pistons have negative 5.4cc "dome volume" and the forged, domed SHP pistons are plus 5.3 cc.
Here's an easy to use online CR calculator:
http://www.csgnetwork.com/compcalc.html
Make sure to enter the "dome volume" and deck clearance with the proper algebraic sign.
Duke
Old Feb 14, 2006 | 05:00 PM
61driver's Avatar
61driver
Thanks for the reply. That is actually the calculator I was using..I think I have it figured out. We'll see if she runs.
Ray
Old Feb 14, 2006 | 11:10 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Yes, my current flat tops have a -6cc volume.
To Piston Dome Volume??
