Flowbench experts check in...
Old Feb 21, 2006 | 08:14 PM
cv67's Avatar
cv67
St. Jude Donor '05
Default Flowbench experts check in...
I have a ported TPI base I want to have flowbench tested, the man running the shop needs to know how many inches of water they (intakes) are originally tested at so I have an accurate reading.
I understand most heads are tested at 18 or 28? in.
TIA
Old Feb 21, 2006 | 09:16 PM
korvetkeith's Avatar
korvetkeith
28" Water. It's generally recommended that the intake flows 10% more than the heads in order to not be giving up HP. You'll also want to port match it to the head's intake runners.
Old Feb 21, 2006 | 10:00 PM
cv67's Avatar
cv67
St. Jude Donor '05
Heres what Id like to do...
Flow the base by itself
Flow a set of stock, and worked over stockers by themselves.
Flow each runner and the base together,
Would it be good to bolt the intake to a head, or a waste of time?
Suggestions?
Im pretty curious, but mainly it would be good info for C4 tech as far as solid info goes.
Old Feb 21, 2006 | 10:06 PM
korvetkeith
I've always thought that flowing an integral head/intake would be an excellent way to compare intakes and head/intake combos. Would be cool to see done.
Old Feb 25, 2006 | 06:33 PM
comp's Avatar
comp
To Flowbench experts check in...
