377 vs 434 SBC??
I am leaning towards the 377 but I am concerned about the street manners of such a motor. To make the horsepower up high, the heads will have to be pretty large (210cc or bigger). Will the car have any umph down low? Will the throttle response be there at 2500 RPM?
Anybody running a 377?
I autocross my car on ocassion and built a 388 (4.125x3.625). Most will recommend the bigger ci because the cost is about the small for both and you get the added torque down low from the extra cubes. I had no problem spinning the tires with my old 355, so I didn't think I needed the extra torque down low, although I did add quite a bit going from the 355 to the 388 anyways.
I have a solid roller cam. The lobe separation angle is 112 degrees. This cam has 4 degrees ground into it to improve the lower rpm torque so when it's installed at 108 degrees it will essentially be straight up at 112 degrees. The lift is intake .616"/ exhaust .622" with 1.6 rocker arm ratio. Duration @ .050 is Int. 248 & Exh. 254 . The cam timing events @ .050 are 16 52 63 11. With the standard shift transmission and the 3.90 rear gears I'm running, I've had nothing but a blast running this engine on the street and it has tons of power.
Do you prefer one builder over the other, and have you talked with others that have had work by them to find out about their reputation and knowledge?
Good luck and keep us updated
Thanks for the response. Both the engine builders I am talking to are very involved in the local racing scene and have very good reps. The one I have chosen builds lots of motors (half the field) for the vintage stock car circuit. He has a dyno in house so he tests everything. Go to his shop and Earnhardt and Yates motors are lying around. This guy will do all the machining, I will screw the thing together, and then go back to his shop for a dyno session.
Your motor is very similar to what we are contemplating. We have kicked around cam specs close to what you are running. What heads do you have? How is the throttle response and pull at 2500 RPM? Any dyno data? DD2000 is showing a very broad torque curve for this motor.
The jpg is too broken up for me to read. What is your peak HP and RPM and what is your peak torque and RPM? I'll also run DD2000 tonight with your cam specs.
I think I'd still be inclinded to go with bigger cubes - even for AutoX - for more torque (4000 RPM isn't exactly "out of the powerband") especially if you're running anywhere near stock rear gears.
Bigger cubes is likely going to be more fun, with more usable power, and will be more reliable on a tighter budget.
Sure you could build it to scream at 7500 RPM - but why?
I built my engine with all small journals to decrease the surface contact area and thus the frictional losses. By destroking and increasing the rod length to 6.0", I also improved my rod to stroke ratio. With the shorter stroke, my engine has less side thrusting when rotating than a stroker motor, this will also decrease friction as the rod pushes the piston straighter up the cylinder bore vs into the side of the bore. Another advantage to this is that you get less wear in your cylinders for longer engine life
I ordered my Dart block with the 4.125 bore and with the 350 main bearings. My rods are also the small bearing journal size so there is decreased rotating mass.
Nascar runs destroked engines, but they are limited to the class rules like any other racing organization, it'd be interesting if they would still destroke if they could run a larger displacement.
Here's an interesting article that one of the mags put out a while ago called "The 350 Chevy should have built".
Now before anyone sends me the "bigger is better" emails, and how de-stroking is not the way to go, I like the super high reving type motors and like I said, it's just for fun. I drive my car, a '63 FI conv. anywhere and everywhere, so a little economy doesn't hurt either. Email me in about a month or so and I'll have some G-Tech times for you.
loup1962@aol.com
3000+ pound Vettes are not light. If you have a traction problem you don't have the correct tires.
I have a 7500 rpm 383 ci and now I also have a 7000 rpm 427 ci small block. I'd never build another sub 396 ci motor again.
Your not going to beat the 434/427 small block with a 377 if you have correct gearing. Lets say that motor "A" 377 makes an average of 500 foot pounds of TQ from 3500 - 7500 and Motor "B" 434 makes 520 lbs from 2500 to 6500. The power range is still 4000 rpm wide for both motors. So your logic about not shifting on the end of the straight is flawed. Change the gearing and the TQ monster will win every time.
When it really comes down to it the 4 .125 stroker small blocks are the best all around small blocks. They are the 441-454 small blocks.
Just because some engine shop has some big name motors sitting around doesn't mean anything to me, because BUBBA does not even grasp the theory of how or why it was built.
In local A-X racing one of the fastest cars week after week is a 71 Vintage racing Vette. It has 496 ci of solid roller big block and a 4 speed. He runs a 390 CFM NASCAR carb to limit TQ and HP for A-X and installs a 900+ CFM for road racing
I don't really understand anyone's reasoning for going with less cubes than more when it won't cost significantly more. Unless you just want to build a super high RPM motor because it sounds cool, there really is no point to go with less stroke than more.
And if you wait long enough for the next Engine Masters Challenge it is going to be engines limited to 434ci. Might learn something!
The point I think they are trying to make is that 500 ft lbs of torque is unuseable coming out of a corner at 2500 RPM. The 377 would have more than enough torque to spin the tires at 2500 RPM at low speed. DD2000 shows more than 400 ft lbs. The torque band of the 377 could extend to 7500, and that is a 3:1 ratio. On the flip side, you might argue the 434 will do that from 2000 to 6000, again the same 3:1 ratio, and it will have better street manners.
And no, I'm not running race tires. But I am running 315 Kumho 710's in a '66 corvette. Even with a 350 350 and 4.11 gears, I can lose traction in 1st. My biggest problem with my present motor is it gives up at 5500 at the end of a straight. And keep in mind this is an autocross car, not a road racer.
Just looking for pros and cons here. I appreciate the inputs.
but the two most competent engine machinists I have found have both (independently) recommended that I would be better off with a 377 (4.155”bore by 3.48” stroke).
3.480 stroke is a stock chevy 350 length. high quality forged cranks are 3.500..................................4 .250
Smoked tires has a super Bryant crank 3.625 or something like that to get his 388 ci and it's small journal like mine for aftermaket blocks like Motown and Dart.
It's not the ci that determines the mannerisms of a motor. It's the whole A/F system and the cam. I tend to go big high flow heads and a smaller solid roller cam duration to keep it tame.
The aftermarket is pretty geared up for this motor. 3.5" crank, 6" rods, and 1.25" compression height pistons are standard catalog parts. This gets you to a zero deck height of 9". Flat tops (-5cc), a 68 cc head, and a .041 gasket land you at 10.5:1 with, of course, a .041 quench.
I out grew hot rodded 383 even though first gear was worthless with my 315/17 inch tires. On an auto-X course I would just drive around in second. I found life after Auto-X and rarely attend SCCA meets. I decided that a higher power to weight ratio was needed.
You actually become a much better driver. Think of real race machines. Very few people can really drive them well.
