Will tape desensitive Knock sensor?
Old Mar 26, 2006 | 02:09 PM
85vet's Avatar
85vet
Cruise-In V Veteran
Default Will tape desensitive Knock sensor?
Just wondering if I use the white tape on stock 85 Knock sensor if it will help to eliminate false knock. I am running a solid roller that has to be considerably noisier than stock.
Old Mar 26, 2006 | 04:25 PM
Bowtie8's Avatar
Bowtie8
yep
check the knock sensor itself for loosness on the plastic nipple. If its loose, replace it. I had mine loose for over a year and with tape minimized the spark counts, but finally when I replace it, it went quiet with teflon tape.
I'm running a solid roller like you
BTW
Your intake. I like it! who set that up for you? Who's base is that?
I have been tossing around a caburator intake settup, but didn't want a cowl hood, so I have stuck with the miniram. I see you and Jesse are getting it all under the hood.
Any leads on this, I am interested.
John
Old Mar 26, 2006 | 07:51 PM
85vet's Avatar
85vet
Cruise-In V Veteran
Bowtie8,
Thanks, I thought so - I freshened the motor so I am replacing it.
Jeb, (jburnet) modified a Super victor JR manafold and manufactured the box. Jesse is running a larger similar style intake ( same setup xcept a Super Victor manafold). Corkvette1 and Ralph are running similar setups. Here is an old post:
http://forums.corvetteforum.com/show...m_id=48&arch=1
At the end of last year I hit my best 60' that I made with the SR 1.51, tuned properly it is bad@ssed.
To Will tape desensitive Knock sensor?
