Supercharger Bypass
Old Aug 20, 2001 | 08:04 PM
AKS Racing's Avatar
AKS Racing
Default Supercharger Bypass
I am just about ready to begin the reinstallation of the new motor combination. As this set-up is totally new, I was considering a way to bypass the plower for the interim. My thoughts were to install an idler in place of the procharger, so that I do not have to remove any bracketry or components. I would also have to plug the oil feed and return, fabricate an air inlet from the existing 3" piping to the 4" K&N, and plug the blow off reference. Granted, I understand that the air will have to be "sucked" through a lot of piping and the intercooler, but this (removal of the boost source) may serve to aid in getting the combo worked out normally aspirated. Then after I get it suitably tuned n/a, I will just bolt the blower back on and I should be that much closer to the final set up.
The motor is a 408 (350 based) with a MRII, AFR 210CP, CC solid roller. The engine has a multistage NOS system. I would just like to take this in steps, to make it easier to tune.
Thoughts?
Aaron
Old Aug 20, 2001 | 10:58 PM
tommelton's Avatar
tommelton
Default Re: Supercharger Bypass (AKS Racing)
Why not let the supercharger spin, and reroute the intake from the TB to a filter in the normal location, if it is still available. If not, put a small cone style filter on the TB.
Tom Melton
82 CE
86 Z51 Coupe
Old Aug 22, 2001 | 12:51 AM
KNEVER's Avatar
KNEVER
Default Re: Supercharger Bypass (tommelton)
Sounds like a scary setup. :D I want one.
To Supercharger Bypass
