Don't know where you get your information, but if you read SAE papers over the years and other research on the physics of shock waves, that's the result. An order of magnitude is "times 10". It's not the mechanical pounding they take, but pistons and valves can fail in a detonation environment because the materials get hot enough to loose considerable mechanical strength. Most aluminum piston alloys loose strength rapidly at over 400F, and most valve materials are working within a 100 degrees of the point where material strength degrades rapidly, so it doesn't take much sustained detonation to cause failure.
coatings are starting to get big over here in the UK. the theory definatly seams to work, especialy if you are running FI. they say you can run higher boost with less det, a very important thing for FI. also the theory would say that coatings would keep the heat where it should be thus reducing thernal stress and reducing the strain on the cooling system. there will allways be two sides to the argument though. some say "what if the stuff comes off" and this is a valid responce. but i think you have to way up the possiable down sides to the garanted plus points. also, over here at least, coat tech is improving all the time.
i personaly would def get the pistons done. i would also get the whole bottom end nittrided just to help out.
Duke
Thanks for the, "times 10", explanation. If you had written, "by up to an order of magnitude of 10.", I would have "got it". Possibly the term, "order of magnitude", infers a factor of 10. If so, I wasn't aware. I don't see any disagreement between my original post and yours, following it. You have gone into more detail and cited consequences, but I don't take exception to anything you've said.
I am a firm beleiver in coatings. A couple years ago I tore my engine back down, and the only thing that I changed was doing coatings. I had HPC Coatings do the piston skirts with a dry film coating, the piston crowns with ceramic coatings. Then I had the chambers, valves, exhaust ports all ceramic coated, and did the valve stems with a dry film coating. I also did the valve springs while I was at it. When I got the car running again, I was amazed how much more fuel this thing wanted. I had to add 7% more fuel to the engine to get the A/F ratio back in line. It had to have picked up at least 25 hp. I never did dyno it, because a while later I made some other changes. But it was very noticable, and the engine requiring more fuel speaks for itself.
I won't profess to know diddly about thermal dynamics and such, because I don't. The only issue I have is with using any type of moly coating in an engine. Moly and moisture do not mix at all. My experience with moly is limited to firearm barrels, but the same principles apply. Few of the top shooters are using it anymore. When moisture comes in contact with moly coated metal, it pits in a big darn hurry. Some shooters clean moly coated barrels between as few as ten shots, when they are going to fire a hundred or more in a day. I wouldn't be comfortable with an engine that was coated sitting all winter. Classic
I don't beleive to be an expert in coatings, but I think the dry film coatings used on the piston skirts and other parts is more like a teflon coating.
Oh... as far as gas mileage, I don't think it would hurt it. I think your making your engine more efficiant. But Jim you are right... gas mileage probably isn't my biggest concern
Classic63 - your talking about apples and oranges. I have a "Moly" barreled target rifle. that is short for "Chromemoly" it's a steel mixture that doesn't have near the ability of stainless steel to resist rust.
Moly coated piston skirts like mine are molendium (sp?) It's and additive to things like wheel bearing grease because of it's friction fighting ability.
I had my roller cam go while out road racing. I had nearly 20,000 bad street and track miles. The ceramic coating was covered in light carbon, but intact. My exhaust valves were nearly devoid of coating on the back and lower stem. I would attribute this to heat and erosion from hot gas roaring out the port. The chamber side face was probably 80%.
The chamber it's self was @95% intact. I did have a bad day with preignition once and it might have been damaged by this.
I had my crank nitrided and coated with oil repellant.
gkull, I was talking about molybendium. It can be applied to bullets and barrels a few differnet ways. It was all the rage for awhile in the shooting world but has lost it's luster in a big way. I cannot say with definetive proof that moly is bad in an engine, because I have not tested it in that application. However, moly's tendence to draw moisture and the results of it coming in contact with moisture would make me shy away from it. Other than the moisture issue, moly is a great substance.Classic
Molybdenum is a basic element - a metal. The additive added to high temperature EP grease is molybdenum disulfide - MoS2. It's about as different from pure molybdenum as water is from it's consituent basic elements - hydrogen and oxygen.
"Moly" dry film coatings are based on MoS2, which is a solid. Piston skirt coatings are gaining popularity with OEs. GM began using "polymer" coated pistons on LS6 engines in late '01. The purpose was to run tighter clearance to reduce customer complaints of cold piston slap, and the polymer coatings allow the use of tighter clearances without increasing the chances of piston scuffing, so it really has nothing to do with "reducing friction".
Hey guys sounds like we ventured away from the ceramic coating and jumped to the DFL coatings used on some hi-pro pistons. I think the orginal post wanted to know more about some of the TBC's that alot of the race teams have started using.
Here is a great site to check out if you are into coatings of this nature: http://www.cermakrome.com/
