Req Tech info on TRW L2300F forged piston
Old Aug 23, 2001 | 09:49 AM
StrayDog's Avatar
StrayDog
Veteran: Marine Corps
Default Req Tech info on TRW L2300F forged piston
The 427 in my 1966 , was rebuilt by previous owner & TRW L2300F domed pistons installed .30 over, , as a winter project I put on a set of Endlebrock Alum heads , the pistons have a dome but :cry , I did not take the time to measure them ......duz anybody, have tech info on this piston ? thanks, the dog. :cheers:
[Modified by StrayDog, 7:50 AM 8/23/2001]
[Modified by StrayDog, 7:51 AM 8/23/2001]
Old Aug 23, 2001 | 11:07 AM
Cory@LS2PortWorks's Avatar
Cory@LS2PortWorks
St. Jude Donor '09
Default Re: Req Tech info on TRW L2300F forged piston (StrayDog)
Have you called TRW? Even Summit Racing's tech line can help you. just tell them you're interested in a set of pistons and need the specs. Go to the source!
Cory
P.S. are you saying that you installed new heads on an engine with domed pistons without getting the specs? You must like spending money....
[Modified by CHarris85Vette, 7:10 AM 8/23/2001]
Old Aug 23, 2001 | 11:50 AM
StrayDog's Avatar
StrayDog
Default Re: Req Tech info on TRW L2300F forged piston (CHarris85Vette)
CORY......The L 2300F piston is the correct aftermarket piston for a 427 , resulting in a 10.2 compression ratio with 96.4 CC chevy heads , Endlebrock tech advised me that there would be no clearence problems with the Alum performer heads with 110 CC, & after 8 ,000 miles no problems, BUT now contiplating a Cam change ( comp cams Xtreme energy 262 ) , as my RPM range is 1300 t0 5500 rpm .....with occasional bursts to 6,000 redline & desire the specifics of the TRW 2300 f , in advance.
Old Aug 23, 2001 | 12:56 PM
Cory@LS2PortWorks
St. Jude Donor '09
Oh.... okay, then. You had me going for a second there! I was worried about what was going on over there
Your best bet is still the proper tech line.
Cory
Old Aug 23, 2001 | 02:58 PM
GregP's Avatar
GregP
TRW piston part numbers tech info is on the web somewhere. I found it when looking for dome cc for my pistons, but alas can't find it now in my bookmark file. I also have a "bunch" of piston dome cc info at home, will try to remember to look tonight and see if your pistons are in my list.
-Greg
Old Aug 23, 2001 | 10:14 PM
StrayDog's Avatar
StrayDog
Default Re: Req Tech info on TRW L2300F forged piston (GregP)
GREGP , THANKS :cheers: for the info from your e mail...............question where could i get ahold of a TRW tech book ??????????????
Old Aug 24, 2001 | 09:33 AM
GregP's Avatar
GregP
For anyone looking, the other info is in the C2 group. Anyway, I checked my Chevy parts listing last night, and they list the dome volume as 16.8cc -vs- the 17.7cc of the NHRA spec. Guess they give you a 0.9cc "margin" to work with. Hey, maybe that's what they mean when they say their car is "more stock" than yours :D .
-Greg
Old Aug 26, 2001 | 02:07 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
I've run those before....
You have to be REAL careful with Piston to valve clearance with 2.19 intakes. The depth is usually OK into the .620 range at least, BUT ck real close at the edges of the valve pocket. I found that the valve can just barely kiss the edge of the pocket even though the depth looks good. Especially an issue if you have much cylinder clearance and have any piston rock.
If you have a very aggresive cam you might need to do a little work in the bottom of the pocket.
The same issue occurs with the TRW's for 390 Hp 454's and the replacements for '71 LS-6's. Even though they will handle the 2.19's they don't like much lift.
2.06 valves cause no problems.
Just check REAL close!!
Jim
To Req Tech info on TRW L2300F forged piston
