High RPM 327 Plan what do you think?
Greg
2. 220 CC intakes and then ported,, on a 327 seems really really big. What do you plan on doing with the car. This sounds like a full on Race set up for drag or circle track cars. What cam would you be using? Just curious.
3. What kind of transmission? 4.11 gears or 4.56's
I will say it sounds totally radical, awesome,, But before you drop all that dough, besure that the entire drivetrain is setup for the high rpm situation you will be looking at,, I would say this combo is going to be down on torque substantially until its spinning above 3700 rpm maybe higher. Reason I say this is that the runners are huge for the displacement and will kill any low end torque. My Dad had a stock headed 327 that turned 7,000 rpm with a solid stock cam all the time. He raced many bigger motored cars and just smoked them.
I'm sure your combo would run strong but you will have to spin that baby up, then hold on ,, good luck,, I appologize if I have offended you by my post.
I'm also running the Milodon Splayed caps. I'll be using the Crower rods in my SJ build. I just received two cranks back from Henry Velasco and I asked him about RPMs on these SJ 4340 nitrided cranks, his response was they can spin up as high as any L J chevy crank and there is no problem with a 3.25" stroke spinning 8K. And as everyone already knows about 383s, he said the only thing limiting my RPMs for the SJ 383 crank is the flow in/out of the engine.
Here is a recent quote from Duke on the NCRS board:
SB cranks up to 1966 all had 2.3" main journals and 2.0" (nominal size) rod journals.
Beginning in 1967 the 350 cranks/blocks (and ONLY 350 cranks/blocks) were designed with 2.45"/2.1" journals, and these journal sizes were extended to SBs of ALL displacements in 1968.
The 400 has 2.65" mains, and IIRC the same 2.1" rod journals as the other contemporaneus SBs.
The reason for the larger journals has nothing to do with the bearing sizes being inadequate. It was done to maintain crankshaft journal overlap with the longer strokes, which is a big factor in crankshaft torsional stiffness.
Back in the early seventies, some F5000 engine builders realized that small journals made more power in those 8000 rev engines, and with only a 3" stroke, crankshaft stiffness was adequate with the small journals, but they offered less friction because at a given speed the surface velocity is less than with large journals, which resulted in a small, but measureable power improvement.
Your (two cranks back from Henry Velasco) cranks are probably not playing in the same field as a stock forging.
I'm using the small journal idea on my Motown 427 small block. Because i think that the 400 type cranks are too large and bearing speed goes up.
The expense of installing spayed caps on an inferior product would bother me. Why not get a newer 4 bolt and install a much cheaper ARP main stud kit and still run 8000 rpm all day long.
This is a local real F5000 that competes in historic races - it's full of modern goodies to make it last longer!
) stroker, is a numbers matched motor except for the intake which will more than likely be a RPM Performer or maybe a Vintage TM-1 Tarantula since they both have provisions for the oil fill tube. Now if only you could get AFR heads that didn't have all those holes drilled in them and had AFR written all over them...darn that original look!
Greg
The old intake breather oil fills are cool for the correct year look.
Will fit w/ 3" Air Cleaner & Speed Demon Carb-STOCK small block hood-No Problem.
Greg
Greg
Major changes there chop. Different heads and cam. Y? I like that cam but why the change from the RHS hds? Find something u didn't like with those? Remember the lash value is subtracted from the vlv lift number to calcutate true vlv lift on a solid cam.
Anyways the longer the rod the better for high rpm breathing - increases the time at TDC and BTC for better cyl filling. I image 6" rods should be easy to find pistons for. 6" rods give u 1.8 rod length to stroke ratio which is great for drag racing (ask any Pontiac fanatic). But if u really want to get fancy there are some 6.25" sb Chevy rods availble (and u would need correct compressed height pistons to match).
Don't test the .035" quench height for a limit unless u have a lot of money and time. It just happens that most composite hd gaskets are .039" or .041" and a zero deck nails a good quench height with little effort.
Good luck and post how that small stroker works out for u.
cardo0
