Ring gap
Old Jun 8, 2006 | 09:51 AM
LD85's Avatar
LD85
Default Ring gap
What should the ring gap be on these?
4.155 Bore Hyper Pistons / Speed Pro
Rings are Sealed Power Performance Piston Ring Sets
Piston Rings, Moly, 4.155 in. Bore, 5/ 64 in., 5/ 64 in., 3/ 16 in. Thickness, for 8-Cylinder,
http://store.summitracing.com/egnsea...ts=false&N=115
Old Jun 8, 2006 | 10:22 AM
CFI-EFI's Avatar
CFI-EFI
Does Speed Pro have a recommendation? Keith Black would like to see the top ring gapped in the .027" to .033" range for their hypereutectic pistons, depending in usage. Are there any shiny spots on the ends of the rings to indicate that the gap closed up and the ends butted together?
RACE ON!!!
Old Jun 8, 2006 | 11:01 AM
LD85's Avatar
LD85
RACE ON!!!
No I could not find any spots that show butting. I think 8degrees abse timing + 42 degrees of advance + 87 octane was the killer.
On the Ring gap, Speed Pro says to use the factory ring gaps.
Old Jun 9, 2006 | 10:17 AM
CFI-EFI's Avatar
CFI-EFI
No butting is good except, if it had, and there were evidence, it could help answer some questions.
It is difficult to observe total timing with a light, as back in the precomputer days, but if you have a scanner and/or a way to read the chip, then I agree the timing was excessive... for any octane. Was that a goof up or a not so wise decision (mistake)?
I'd stick with Speed Pro's advice on the ring gap.
RACE ON!!!
Old Jun 9, 2006 | 11:33 AM
LD85's Avatar
LD85
RACE ON!!!
Timing was set at 8 degrees, max in the chip was 41.5, chip was programmed by someone else, which will remain nameless
To Ring gap
