Valve spring Diameter & pocket
Old Jul 8, 2006 | 09:41 AM
Lee H's Avatar
Lee H
Default Valve spring Diameter & pocket
My newly aquired Alum heads have a spring pocket diameter of 1.47. My Comp cam bee hive springs have a diameter of about 1.30. Can I use these smaller diameter springs in these heads? Thanks Lee
Old Jul 8, 2006 | 11:31 AM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
I wouldn't see why not. Make sure you have adequate clearance for your seals too. But if all parts are compatible and set up properly, this shouldn't be a problem either.
Old Jul 8, 2006 | 04:10 PM
babbah's Avatar
babbah
IMO - The use of a spring cup that sits in the pocket and matches the outer diameter of your springs to sit in would "BEE" best.
I use spring cups on my BBC with aluminum heads. The cup protects the head from the spring galling the aluminum, much better than just a valve spring shim or spacer. Keeps the spring perfectly positioned so the bottom of the spring can't walk....
Old Jul 8, 2006 | 07:16 PM
Corvette Kid
I'd certainly expect that he'd use some type of cup. Perhaps I was assumming. I use stock LT1 cups w/ CC 26918 beehives on my LT1 aluminum heads and they have no outer ridge. But their OD is adequate that the springs are a bit from the edge. No problems in 20K miles.
Old Jul 10, 2006 | 09:25 AM
Lee H's Avatar
Lee H
Thx all. I found a set of comp cams spring locators built for my specific springs.
Old Jul 10, 2006 | 05:38 PM
comp's Avatar
comp
To Valve spring Diameter & pocket
