on wire alternator
Old Aug 3, 2006 | 01:10 PM
Chewie46's Avatar
Chewie46
1st Gear
Default on wire alternator
I'm wiring a 61, 283 4 speed. How do I wire the amp gauge to work with the 1 wire alt? thanks......Matt
Old Aug 3, 2006 | 06:15 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Is it a standard or a shunt type gauge?
Old Aug 3, 2006 | 06:37 PM
toddalin's Avatar
toddalin
The easy way to to simply put a voltmeter at the alternator hot lead. If you're not seeing in excess of about 13 volts, you're not charging your battery. You should easily be able to see the needle deflect to the right if the alternator is charging, and isn't that really all you need to know at a glance?
To on wire alternator
