intake manifold and runner questions
The TPIS is an Edelbrock port matched to AS&M runners. I bought the Edelbrock setup and had a lot of fit problems and a lot of port work to do. After all that work, it only flowed 8% better than a fully ported stock setup.
I recently received my Accel base intake and intend on installing it in two weeks time. So far I've just had to grind away a little bit of excess casting from the ports but overall it looks like a good piece. When I do the swap, I'll post it if there is a noticeable difference (on the SOTP dyno that is
) Current mods are in my sig (except for some minor exhaust mods).Not sure if I WILL notice a difference but I bought the intake now for three reasons:
1. I understand that the intake on L98's is designed for a 305ci motor and is therefore a restriction in the motor.
2. I know alot of (most) ads claim way more hp for parts than they actually deliver, but if Lingenfelter claims 15-20hp on an otherwise stock L98 in their catalogue I think (hope?) that their claim is a little more reliable than those made by others.
3. I got it really cheap on a group purchase.
Don't know if there is enough 'meat' on the stock runners to allow any significant porting... I've heard that of the large tube runners available, Arizona Speed & Marine's runners fit the best.
HTH
