teach me somthing: solid vs. hydraulic lifters
That is all I have the energy for this morning.
RACE ON!!!
Really? Do you run your solid lifters at zero lash?
RACE ON!!!
A valve can't pump nor a can an orifice. But anyone with a brain larger than a pinhead can see that the (solid) lifter does infact provide a pumping action to force flow oil up the p-rod to the rocker assembly.
And the point i made was that the oil flow up the p-rod was not pressuerized from the dist driven oil pump (through the oil galleys) but from the lifter itself - but i now read that someone remains clueless as usual. At least he found the right lifter nomenclature - he probly had too good a time researching names of lifter parts and wants to act like he might understand them too.
And the vlv does still see full lobe lift on a solid cam/lifter - while a hyd looses lift due to pre-load and leak-down. You always have to subtract lash from the advertized lift to find the actual lift. If u don't know that and assume advertized lift is used to compare a solid cam to a hyd u ain't worth the effort to explain why.
Yes save your energy for shopping a solid cam using full lift values - u gonna need it.
cardo0
You should get your facts straight before you start expounding on how things work, and especially before you get derogatory toward others about it.
Dan
It is interesting that YOU recognize the names of the lifters, that you wish I had to look up, to know. If you had known them YOU would have used them in your initial work of fiction. I wouldn't be throwing around accusations like "clueless" or commenting on brain sizes, if I had written some of the foolishness you have, including your "lifter pump" fabrication.
So WHICH is it?
cardo0
And speaking of a waste of effots...RACE ON!!!
Dan
Ok Dan, I made a google search and only found a pix of an Isky solid lifter which uses a Fluttering Type oil metering vlv. Take a look at http://www.iskycams.com/racingcamseries.php. This oil metering vlv is as good as a pump to me as it precisely controls oil flow to the rocker arms. This oil output is not at oil pump or oil galley press. To me this is a pumping action as the solid lifter is controling the oil flow - not the dist driven pump which only fills the lifter with oil.Thx for your curtious reply Dan and i hope u can consider this reply as a constructive debate. But i really don't the have time to keep defending every post that i try to help someone with from the obsesed fault finding attacks of others that provide no useful explainations.
Have a good holiday weekend, i will.
cardo0
THinking outside the box can be good but in this case dont mix and match. Lots of R&D goes into these parts to make them work with eachother approproately.
Im outta here, its getting a little steamy
If you are looking for a cheap retrofit roller lifter (hyd.) C.A.T. sells some for $152 per set. I havent used them personally but Ive used thier lower end parts with no problems.
And thanks for the cheers - same to you!
Dan
RACE ON!!!
Dan
Hello Dan,
Well yes, the concepts are confusing as others have also posted. Like that Isky lifter meters precise oil press at all rpm. So what does it do at low rpm and low oil press? Maybe pump? Maybe not? I just don't think enough information of the full dynamics is availible. And the edge orifice type uses the volume change between the lifter bore and lifter body as the lifter moves up and down the lifter bore to "meter oil" - very piston pump like while again the full dynamics of this were not explained and true oil pressurizing action debatible.
Well i made an effort, read the Chevy Power Manual to find it descripes it only as "metering" and that well may be the correct nomenclature but all others had failed to post this as a metering until i did in post #25. Also the manual does not explain the lifter oiling dynamics fully. Clutchdust and Gerorge touched on theese dynamics before. The triggering of the "metered" oil in spurts that travel up the p-rod into/around the engine compartment and sometimes onto my shirt is not a constant flow. But yes my guess is the lifter motion over ther cam ramp is the controlling mechanisim.
As i originaly posted i didn't recall the name of these "tiny pumps" but now that i realize the actual term is "meters" i would have have to call them "tiny metering valves". And no-one mentioned metering untill i took the time to look it up with meerly a Google search. Big deal, tiny metering valve or tiny pump, this wouldn't make a college proffessor blink. No, i won't research the full dynamics of the lifters oil metering as it is now apparent how the job gets done and the end reason for this - enough. This becomes a federal case because some crazed and frustrated fault finding fanactic just Can't Find It!
Someone with a pinhead sized brain and just a needle at the other end still thinks a solid cam's lash is lost lift is just soo frustrated, Can't Find It, and doesn't warrent the effort for explaination.
Maybe a sorry, sour, unemployed rocket scientist has time and energy for these fault finding missions but i don't. I don't want to/won't waste time researching flapper vlvs dynamics for someone that can't even figure actual lift values.
Again enjoy a nice weekend.
cardo0
Your family has my sincere condolences.
RACE ON!!!
