Paging SWCDuke
Old Aug 23, 2006 | 02:14 PM
Chalky's Avatar
Chalky
St. Jude Donor '08-'09-'10
Default Paging SWCDuke
Duke:
based on your endorsement, I just purchased EA 3.2. Would you mind sharing the settings for intake and heads assuming LS6 pieces? Without knowing cylinder intake runner diameter, I have to guess at runner length.
TIA
Old Aug 23, 2006 | 03:53 PM
SWCDuke's Avatar
SWCDuke
I don't actually have a model for the LS6 heads - but there may be a LS6 head model in the program library.
I did build a model for the LS7 heads. Basically what you need to build a head model is port volume, port lengh, flow data, valve sizes, and compression ratio.
If there is no model in the V3.2 library that's included with the program, I'm sure the data you need to build a model is out there if you do a little digging. The C5 Z06 forum is probaby a good place to start.
Duke
Old Aug 23, 2006 | 04:10 PM
Chalky's Avatar
Chalky
Thanks Duke. I am .in the process of trying to pull some of the data in. Runner length and intake diameter ae giving me a problem.
Old Sep 10, 2006 | 11:17 PM
Chalky's Avatar
Chalky
Duke:
Any chance you could share your LS7 intake dimensions? I started modeling my LS7 tonight. I captured some decent cam and max flow number for the head/cam. Intake dimensions are my bottleneck currently.
Old Sep 11, 2006 | 11:13 AM
SWCDuke's Avatar
SWCDuke
Single plenum EFI, 2" diameter runner 6.5" long, 92.5% flow efficiency, 1000 CFM@ 1.5" TB flow,
Exhaust system - streamlined manifolds, 750 CFM@1.5" flow.
.050" lifter rise valve timing (18)-49/52-(2) lobe lift .3283 both sides, 1.8:1 rocker ratio, aggressive roller hydraulic lifter
2.204" dia. inlet valve, 2" dia., 257cc inlet port, 5" long, 59.6% flow efficiency
1.614" dia. exh. valve, 61.5% port flow efficiency
My model has SAE net torque/power at 471/509
Duke
To Paging SWCDuke
