i'm just curious to know what the advantages/disadvantages are between the two in the given scenario.
say you wanted to run an iron block with aluminum heads. to keep it pump gas friendly, you shoot for a static compression ratio of 9.5:1.
to achieve this you can go with a small chamber and flat or dished piston *or* a larger open chamber design with a domed piston.
what would be ups and downs of either way?
A dome can get in the way of both the flame front travel and the A/F mixture swirl. I don't see the down side to a dished piston, but it is said that a flat top piston is the most efficient.
Even 10:1 on pump premium is feasible with heart-shaped, high-swirl chambers and flat top or D-dish pistons. Know your cam's intake valve closing angle and take DCR into consideration when choosing a piston, head, cam combo.
