std 4-bolt vs splayed caps
Old Nov 20, 2006 | 01:09 AM
MarkBychowski's Avatar
MarkBychowski
Default std 4-bolt vs splayed caps
Hi all.
I'm pulling together parts for a new engine (LTX). Haven't landed the details yet, but looking for around 500 crank HP with the ability to do 7K-ish RPM. Mostly roadrace and street (endurance and sustained high RPM, not drag-race).
I already have a spare 4-bolt block I was planning on using. Assuming the rotating assembly is appropriate, for this type of motor is a standard 4-bolt OK or should I pick up a 2-bolt block and splay it? I thought about just getting billit caps for the standard 4-bolt, but haven't seen them available anywhere. Not overly concerned about the cost since machining and caps are cheap compared to a new bottom-end.
Thanks!
Old Nov 20, 2006 | 12:43 PM
bence13_33's Avatar
bence13_33
If it were me I would just run the 4 bolt block and buy some ARP main studs and it will easily take 7000RPMs. Billet main caps would also be a plus.
Old Nov 20, 2006 | 09:39 PM
BLOCKMAN's Avatar
BLOCKMAN
Originally Posted by MarkBychowski
Hi all.
Thanks!
We machine alot of 4 bolt blocks for splayed caps and your LTX block must an 94 as I believe that was the only year they used a 4 bolt block.
Just going wiith a standard 4 bolt billet caps still put all the stress on just the main webbing of the block as a splayed cap pulss on the pan rail and ties the pan rail and the webbing together.
We use caps from Kenny at Program=Engineering and we use the flat bottom ones with the outter bolts at a 10 degree angle as some caps are at 15 to 22 degree angle and when drilling and tapping there is a good chance of gettin into the water jackets.
Using flat bottom caps you get a much better fit the using a stepped cap which in most cases fit to tight in the registers.
Here is a pick of a block we put caps on for another shop.
Old Nov 21, 2006 | 09:42 PM
Ironcross's Avatar
Ironcross
Now thats a nice job!
BlackIce86's Avatar
BlackIce86
Default Caps
Good info Blockman. What are your thoughts on overboring the mains on a 350 block to the 2.65" on the 400? Is it worth the extra overlap between the crank main journal & rod journal?
Old Nov 21, 2006 | 10:33 PM
63 340HP's Avatar
63 340HP
This thread raises a question about a similar thread in the C1/C2 section regarding line boring an '870 327 block to 2.45" (350) main journals. Is it worth the trouble to fit 4-bolt splayed caps to an '870 block, and is there enough web strength to line bore the result and maintain the block integrity?
The goal is a period correct C1/C2 look and crankcase vent system with a longer stroke crank in an '870 block (3.48, 3.5, 3.5625, or 3.75), and gain the benefit of the mid-size main journal for overlap and crank stiffness. The 350/400 based crank also allows the builder to exploit the ample supply of rod lengths and inexpensive alternatives to stock rods (as opposed to the weak stock & custom world of small journal rods).
Will splayed caps and line boring an '870 block to the 2.45" main journal diameter weaken or strengthen the final assembly?
Old Nov 22, 2006 | 07:39 AM
BLOCKMAN's Avatar
BLOCKMAN
The only problem with doing the the bolt pattern is wider on the 400 blocks and I believe you will be into the bolt holes plus accuratly machining the tangs to there proper location would be another issue.
Old Nov 22, 2006 | 07:50 AM
BLOCKMAN's Avatar
BLOCKMAN
The 327 blocks have a much weaker webbing compared to the 350 block and to machine a bigger bore in that block would weaken the webbing of the block.
Over the years we have installed many set of splayed caps on the old 327 blocks for our engine shop and other shops as well as alot engines builders use this block for there circle track engines and use a Honda rod 283 mains as this frees up some bearing friction and the cranks we have used weigh around 31 pounds when balanced.
Now I do have a 327 block that is double tanged and right now its a 327 main line and is also tanged for a 350 main and it has the good 350 webbing and takes the 1 quart spin on filter.
I can up load a pic if some one wants to see it.
Old Nov 22, 2006 | 02:02 PM
63 340HP's Avatar
63 340HP
Great first-hand info
I would like to see the 327 if you have a chance to post the photo.
Is this one of the '67 transition era blocks with the 350 main webs and the small journal bore?
Thanks.
Old Nov 22, 2006 | 03:53 PM
Scott Marzahl's Avatar
Scott Marzahl
Further to Ed's question, is it a "512" crate engine block with a late casting date?
Old Nov 23, 2006 | 02:16 AM
MarkBychowski
Thanks for all the info!
To std 4-bolt vs splayed caps
