Stronger C4 halfshafts????
Old Oct 14, 2001 | 10:03 PM
Tomulrich's Avatar
Tomulrich
Default Stronger C4 halfshafts????
Anyone ever heard of breaking an aluminum halfshaft in a C4? Does anyone make a stronger halfshaft other than Lingenfelter(way to expensive)...post any ideas or advice thanks.....
Old Oct 14, 2001 | 10:11 PM
Monty's Avatar
Monty
Default Re: Stronger C4 halfshafts???? (Tomulrich)
Tom's Differentials, as well as Denny's Driveshaft, offer stronger than stock halfshafts.
Old Oct 14, 2001 | 11:19 PM
Tomulrich's Avatar
Tomulrich
Default Re: Stronger C4 halfshafts???? (Monty)
Thanks Monty: I am still completing the 4L80E conversion...coming along great ......Are the halfshafts that Tom's sells aluminum? Do you know a round about price?.....which would you go with a Dennys or Toms halfshaft? Do you think this is a good investment if I plan on running in the 10's...and then maybe add nitrous?.....Just went to the Orlando fastest street car shoot out......great show...really got me hyped...Thanks for the reply.....
Old Oct 14, 2001 | 11:23 PM
Tomulrich's Avatar
Tomulrich
Just purchased a 4:11 dana 44 rear ...with all the goodies...shot peened/polished case, extra clutch packs, heat treated ring pinion, 1350 yokes(front and side) cold stabilized/ heat treated/gold anodized, and the same with the outer splined shafts...heat trated cold stabilized/ anodized.....spent alot of money...but I cut no corners.....think the half shafts should be replaced?
Old Oct 15, 2001 | 12:20 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
Monty, I thought Tom's did not offer any replacement upgrades for the shafts themselves. :confused:
The weak spots are the outer spindles, the u-joints, and the spider gears inside the differential. Most people find these first. I have only seen or heard of the two people spinning the actual halfshafts.
Old Oct 15, 2001 | 03:32 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Default Re: Stronger C4 halfshafts???? (Vette92)
I was looking into torque biasing differentials. ( gears not clutches )
Your a drag racer why would you want it you ask?
It's rated for 1000hp
Bad news? $3,000 :eek:
If you want here's Quaife's WedSite
http://www.quaifeamerica.com/
BTW this is based on the unit Archer ran in his Viper for the SpeedVision GT
3 seconds per lap gain! :eek:
Old Oct 15, 2001 | 04:29 PM
Lohkay's Avatar
Lohkay
Default Re: Stronger C4 halfshafts???? (BrianCunningham)
Very nice Bryan...but very costly for a differential.
Old Oct 15, 2001 | 06:02 PM
Tomulrich's Avatar
Tomulrich
Default Re: Stronger C4 halfshafts???? (Lohkay)
Well I made my final desicion. There are alot of ways to go. I ordered the nitrous ready 3" steel half shafts with spicer u-joints. These are custom made from Dennys drive shaft.....he told me that they would handle the most HP.(he would not even sell me the aluminum half shafts when I told him that I am hoping to make 600 HP.) They are 169.00 each with u-joints. I am also using cold stabilized and heat treated outer yokes(from Toms differential)....I think this is the best and most reliable setup...with a set of sticky slicks! .....any opinions????
Old Oct 15, 2001 | 06:47 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
I guess now I know there is an upgrade. I am in excess of 600hp an running the aluminum ones just fine as are some of my buddies. I guess when I break one I know who to call ;).
Old Oct 16, 2001 | 07:52 PM
Tomulrich's Avatar
Tomulrich
Cancelled my order with dennys driveshafts. I was told the steel will not flex like the aluminum....this will cause a break in the small bolts which hold the U straps down...they are the weakness. No one makes stronger / bigger bolts for the 1350 corvette units....aluminum allows some flex..and takes some stress of off the bolts and straps.
Old Oct 17, 2001 | 11:20 PM
Red Rocket's Avatar
Red Rocket
Was headed the same direction you were and made the change back to aluminum. There is a shop in Florida that was going to make up a special bolt and strap set up though.
Old Oct 18, 2001 | 10:18 PM
Tomulrich's Avatar
Tomulrich
Default Re: Stronger C4 halfshafts???? (Red Rocket)
Actually changed my mind again. I have the shafts being made. Spoke to Denny for 45 min. He would not even sell me aluminum upgrade halfshafts..he could have gotten double the money....he said you will not break the straps or bolts.....he has 25 years experience....he said the factory aluminum/any aluminum halfshaft will fail....he said it has no flex..it is brittle and will break. He said breaking a bolt or strap will occur if 1. bolts not torqued correctly 2. weak universal 3. cheap universal 4. very bad universal angle at start (squatting). He sounds very knowledgable....and told me I could cancel my order...with no problem....he WOULD NOT sell the aluminum to me..he told me he didnt want his name on something that will not withstand the HP and would break. I bought the halfshafts..they are on their way.!!!!!!!!
Old Oct 24, 2001 | 01:00 AM
BBA's Avatar
BBA
So how is your 4L80 project coming? How did you mount the torque tube and trans?
Old Oct 26, 2001 | 09:20 PM
Tomulrich's Avatar
Tomulrich
Default Re: Stronger C4 halfshafts???? (BBA)
It is coming along great....fabricated a bracket to hold the torque tube/c arm...will need to shorten the c arm 3 inches..and get a custom drive shaft...tranny fit in very well....clearanced approx 2" on each side for exhaust..tranny fits with no clearance problems.....Will post more as it is completed...going to be real nice/and durable when finished!....
Old Oct 26, 2001 | 11:25 PM
snaketr's Avatar
snaketr
Have you thought about carbon fiber halfshafts?
To Stronger C4 halfshafts????
