New engine question.
Old Apr 11, 2007 | 05:02 PM
devilfish's Avatar
devilfish
Default New engine question.
Hey
Got a new build engine. I just started it and let it idle for 40 min, fixing the fuel and the timing.
Now i drained the oil to put in new fresh one.
I got no experince with newbuild engines. And I noticed that on the bottom of the bucket ( the one I used to drain the oil in), I can se tiny aluminium colored "flakes". Its not big parts, or its not much, but when you tilt the bucket against the light you can spot it. Is that normal during the break-in?
I checked the rockers and the pushrods for wear, but all is fine there.
I also noticed "darker" areas in the oil, like "soot"/"carbon" in the oil. i guess thats normal, and perhaps could be from the super rich A/F i hade at the first startup?
its a hyd roller cam.
Old Apr 14, 2007 | 05:54 PM
machineman's Avatar
machineman
Are you sure it is aluminum? It could be the moly lube as it will sparkle in the oil a bit.
Old Apr 15, 2007 | 12:04 PM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
Default Keep an eye on the oil and filter.
Can u pick up the metal flakes with a magnet? Now bearing materal is non-magnet alloy. Cut open the oil filter and inspect for metal as u put miles on the car. U can buy oil filter cutters from several parts warehouses. Also use a magnet oil drain plug. BTW many install/epoxy magnets inside the lifter valley to catch iron metal particles. I would expect some metal on break in but not eccesive. If u continue to have problems then drop the oil pan and inspect the main cap lower bearings - the lower caps will see the worse of wear and material if any exist. FYI i found metal particles and bearing gouges in my #4 main and #8 rod bearing after wiping 3 cam lobes (wiping my secound cam too).:o
It impossible to know how clean the block was during assembly and crate motors will have less cleaning details performed than a DIY built engine (at least mine). But u can buy motor flush additives to use before oil changes - i like seafoam addititve.
Good luck.
cardo0
To New engine question.
