Most reliable electric fuel pump? C2 FI
Old Apr 27, 2007 | 11:29 AM
63FI's Avatar
63FI
Default Most reliable electric fuel pump? C2 FI
I recently picked up a Bow Tie block that has no provision for the standard mechanical fuel pump. My car is a '63 with the stock FI unit. So standard 7psi range is all I need. Maybe a 2X4 ram quad sometime. So yea, 3/8 fittings are good. My main concern is reliability. I drive the car anywhere and everywhere, so I need something very reliable.
What one would you suggest?
Thanks, Lou
Old Apr 27, 2007 | 02:25 PM
gkull's Avatar
gkull
I had the holley blue 110 for many years on my street rod using a regulator and a 1/4 return line with a restrictor in it. You have to restrict the return flow or else you can't get the fuel log to get very much pressure.
http://www.holley.com/types/Electric...Carbureted.asp
Old Apr 28, 2007 | 09:03 PM
cv67's Avatar
cv67
St. Jude Donor '05
The new Holley black pumps have had tons of failures, Id steer clear.
Old Apr 29, 2007 | 11:14 AM
CFI-EFI's Avatar
CFI-EFI
You shouldn't need a separate restriction in the return line. That is what the proper regulator is and does when properly located.
RACE ON!!!
Old May 2, 2007 | 06:10 AM
Zimo's Avatar
Zimo
Mallory makes good pumps. Just make sure you get the one with the regulator & return as stated above. Remember, the best place for an electric pump is as close to the gas tank as you can get. I used the smaller gas tank vapor line in my '70 as a return. If you need to fab a return line, use only metal.
When you wire it in, install an oil press cutoff for safety. Ford also sells an inertia switch that kills power with a mild impact. When you do find a place to mount it, keep in mind it will be noisy & it will xmit it thru the frame, etc - use rubber isolators.
Old May 11, 2007 | 09:54 PM
KyleDallas's Avatar
KyleDallas
Aeromotive has a very good reputation for reliability and longevity.
http://www.aeromotiveinc.com/
Old May 21, 2007 | 04:20 PM
RacerX70CC's Avatar
RacerX70CC
Aeromotive Tsunami....
To Most reliable electric fuel pump? C2 FI
