Need burnout power
and a Street/Strip Converter. Trans-brake will let you rev like a
manual and launch hard.... converter will let your actual RPM at lock up be a little higher....
The trans brake will only help the engine rev as high as the converter will allow. And since the trans brake locks up the transmission, there is no drive train motion including NO burn out while using the trans brake. Except that it doesn't do what the OP wants to do, it's a great idea.
RACE ON!!!
http://www.hurst-shifters.com/catalo...RollContrl.pdf
On slicks, be aggressive and go quickly to second gear, holding mid-revs for quicker results without as much wear and tear. But, don't roll out of the water while hard on the gas with the stock drivetrain, or you may hear some expensive noises. Rather, pull forward and then do one or two short "dry-burnouts" without the lock on to clean the tires and test traction.
On street tires, its easy to over do the burnout, as true street tires (not DOT legal racers) don't necessarily respond well to high temperatures. It's more important that they be clean than too hot.
btw... that 600cfm carb is too small, but I'd keep the vacuum 2nds with that auto...
Hope that helps you get hooked up!
