Carb build up...should I?
Old Nov 1, 2001 | 06:56 PM
Jvette73's Avatar
Jvette73
Default Carb build up...should I?
Check my sig and you will see what I have. The Holley 600 on the car now is the same as when it came out of the box. Im thinkin I might be able to get some more performance with this carb if I do the right things. So far I put a lighter secondary spring on it. It improved performance. Should I try and upsize the primary jets? Anyone know what size primary jets first come in the 1850 600? The sparkplugs are clean with no black soot after considerable use. The moter seems hungry. How many sizes should I go above whats already in there? Or should I leave it alone?
_______
Old Nov 1, 2001 | 07:28 PM
QuickVet's Avatar
QuickVet
Default Re: Carb build up...should I? (Jvette73)
i dont know how much more power you would get from going with larger jets, but i think it is safe to say there will be more power with larger ones. i would go up only a couple sizes at a time.
Old Nov 1, 2001 | 08:43 PM
clem zahrobsky's Avatar
clem zahrobsky
Cruise-In I Veteran
Cruise-In II Veteran
i would go with a vacuum secondary 750 if you have deep gears,and you will better top end performance. 600 is a little small.
To Carb build up...should I?
