Clutch noise???
Old Nov 5, 2001 | 01:59 PM
rainman69's Avatar
rainman69
Default Clutch noise???
So, I have this groan/chatter that is only sometimes when in gear and the clutch pedal is fully pressed to the floor. Is my throwout bearing going or could it just be a loose linkage?
I will replace the clutch (and all hardware) if necessary, but dread digging it out of m C3. :smash:
Old Nov 5, 2001 | 03:20 PM
Desertvette's Avatar
Desertvette
Default Re: Clutch noise??? (rainman69)
Time to take it apart. The growl is usually the pilot bushing spinning in the end of the crank/or the throw out bearing going. As for the chatter, it's usually the pressure plate to clutch. Only way to tell whats going on is remove and inspect. Good luck
Bob
Old Nov 9, 2001 | 08:21 PM
rainman69's Avatar
rainman69
Default Re: Clutch noise??? (Desertvette)
The growl was the pilot bushing. The squeal was a clutch disc with close to ZERO friction lining left on it.
Pictures soon.
Took less than 7 hours to replace (all by myself). :smash:
To Clutch noise???
