Does anybody have any flow numbers on these heads? Does anybody know where I can find some flow numbers on these heads?
The reason that I decided not to use the "049" heads was because they would only allow my engine to make 525HP @ 5500RPMs before the power would drop off. I want to rev the engine to 6500RPMs. I believe that these heads will allow my engine to make a lot more power than the cast ones that I initially intended to use.
From: Pettis Performance 565 with two stages of Nitrous Supply nitrous 1.082, 4.61 at 155, 7.17 at 192
Re: How Well Will These Heads Flow? (bence13_33)
Are you sure you want rec. port heads. I put a lot of research into my heads before I Bought them and went with the Edelbrock Perfromer RPM Oval heads. I make approximately 600 Hp at the flywheel. If you go with the rec. port heads make sure you have enough cam to complimant them. I would call Edelbrock and ask them. Tell them your set up and I would bet a nickel they will recommend the Oval port heads. :chevy
