350help
Old Oct 11, 2007 | 03:09 PM
chev350's Avatar
chev350
2nd Gear
Default 350help
I bought a 72 Vette with a pooched engine. I have a 350 block that I built up to swap in. It has a 675cfm Holly carb, single plane high rise intake, scat crank flat top pistons and the cam have .501 lift (int/exh). MY QUESTION IS: I have stock 305 heads on right now with some comp cam springs. Is there any other SBC heads that will give me better compression and flow?? How are the 327 heads? CC's and Valve sizes? PLEASE help
Old Oct 11, 2007 | 03:17 PM
ratflinger's Avatar
ratflinger
NCM Grand Opening Veteran
St. Jude Donor '11, '17
Yes, all others. Why don't you just get some nice Vortec heads? Of course you'll need a new Vortec style intake, but you're going to need a new intake anyway. Single plane on that engine is useless. You will need to know what pistons you have so you can match pistons to combustion chamber w/o going over about 9.5 CR.
Old Oct 11, 2007 | 06:14 PM
knight37128's Avatar
knight37128
Nothing will bolt to the 327 heads.
Look at the after-market heads (you will have about the same amount of money in them after it is all said and done).
Old Oct 12, 2007 | 05:25 PM
chev350's Avatar
chev350
2nd Gear
Default Much Thanks
Thanks Guys!!
To 350help
