Coolant Pressure Modeling
Old Dec 9, 2007 | 10:33 AM
Slalom4me's Avatar
Slalom4me
Default Coolant Pressure Modeling
Has anyone gathered or come across coolant pressure data
measured at various points throughout a Gen 1/Gen II (OEM
roller/1-pc rear seal) SBC? Info on other V8 applications is
also welcome.
I am interested in what the testing conditions were, as well
as the values recorded simultaneously at locations like:
  • Inlet/Outlet of pump.
  • Front/Center/Rear of block
  • Front/Center/Rear of heads
  • Front/Rear of intake coolant ports
Details about attempts at remediation and conclusions if possible.
Thanks,
Ken R.
Old Dec 23, 2007 | 02:53 AM
SNW Vette's Avatar
SNW Vette
Default Pressure Drops of Cooling System
http://www.stewartcomponents.com/tec...ech_Tips_6.htm
...pressure drops at a given flow for all the components of the cooling system.
Following is a typical Winston Cup engine at 100 GPM:
Lower radiator hose = 1.5 PSI
Block and cylinder head - each (at 50 GPM) = 8.5
Outlet manifolding = 1.25
Top radiator hose = 2.25
Radiator = 1.5
Total = 15.00 PSI
