Porting Intake Manifold or buy new?
I have an intake manifold (Weiand #7525) which matches to a 1204 gasket and heads (AFR 195) that match a 1205 gasket. I'm thinking of either:
Porting (or having it ported) my existing manifold or
Buying a Weiand #7530, running a spread bore carb adapter and a 2.5" filter element (replacing my 3" element).
The other components of my engine are Q-Jet carb, Comp Cams (XR274R) solid roller with 236/242 duration @ .050 and a redline at/about 6500 RPM.
Also, the heads have been milled (and the block decked) and although the manifold goes on w/o leaks, it makes me nervous how difficult it is to get the bolts in, so I'll probably need some machine work either way I go.
Regarding the use of a smaller air filter on a 7530, make sure you are not bringing the air cleaner lid too close to the carb mouth causing a restriction.
I my memory is correct the 7525 is an open plenum manifold.Use it! Port match but leave the floor of the runners on the manifold alone or not port matching would be ok also.Use the 1205 gasket.Small to large = velocity.I think you really need a Holley 750 double pump list#4779.It will distibute fuel better than the Q-jet at high RPM and the pulses from the intake tracks won't affect the secondarys.Have you tried header bolts in the difficult spots?
