Torque specs for Brodix heads
Old Dec 8, 2001 | 06:10 PM
11sec84's Avatar
11sec84
Default Torque specs for Brodix heads
Bolting on a set of Track 1's and I need to know the torque specs. I'm using ARP head bolts and it is for a small block. The cast iron heads use a torque of 65 ft lbs but the aluminum heads require a different setting. Any and all help is greatly apprreciated.
Thanks.
Old Dec 8, 2001 | 08:22 PM
clem zahrobsky's Avatar
clem zahrobsky
Cruise-In I Veteran
Cruise-In II Veteran
Default Re: Torque specs for Brodix heads (11sec84)
same as cast iron but make sure you use washers with oil under the bolt heads. if you use a different torque spec the cly wall distortion will be different that what was used to hone the bores. :chevy
Old Dec 8, 2001 | 09:06 PM
Lt1er's Avatar
Lt1er
Default Re: Torque specs for Brodix heads (clem zahrobsky)
Did you check the Brody web page. My buddy did unequal torque on a set of A heads. But I don't remember why. It seems to me that it was 10 higher around the cylinder bores.
Old Dec 9, 2001 | 02:01 PM
ralph's Avatar
ralph
i torqued mine to 70 with permatex 2 on the threads. If you use the ARP stuff the reqired torque is less, but i don't remember the specifics.
Old Dec 12, 2001 | 04:16 PM
Mez's Avatar
Mez
From: Austin, Singapore, Kuala Lumpur, Houston, Dallas, Hong Kong, Elgin, etc.. Texas
Go to the ARP website and look up the torque specs if you are using their bolts. They have it for your heads.
Old Dec 24, 2001 | 02:02 PM
mountainmotor's Avatar
mountainmotor
I was just at the Brodix site.The information is there.
Old Dec 24, 2001 | 02:11 PM
korvetkeith's Avatar
korvetkeith
Default Re: Torque specs for Brodix heads (mountainmotor)
What sort of brodix heads did you 11sec?
Old Dec 25, 2001 | 03:20 AM
11sec84's Avatar
11sec84
Default Re: Torque specs for Brodix heads (korvetkeith)
I went to the siite as you guys suggested and got all the info. Thanks for the help guys. The heads I have are the Track ones with a bit of work done to them.
To Torque specs for Brodix heads
