Lt1
Old Mar 28, 2008 | 07:39 PM
auctionman256's Avatar
auctionman256
Default Lt1
what can i do to get more power out of my 93 LT1 vette motor?
Old Mar 30, 2008 | 12:11 AM
64_365's Avatar
64_365
Upgrade to LT4 specs is easy, if not cheap.
Old Mar 30, 2008 | 10:56 PM
auctionman256
anything else
Old Mar 30, 2008 | 11:17 PM
cv67's Avatar
cv67
St. Jude Donor '05
cam, port your stock heads and intake; longtube headers and a good tune.
Old Apr 1, 2008 | 02:51 AM
1981Z06Vette's Avatar
1981Z06Vette
A stroker crank is a good upgrade, and they are a lot cheaper than they used to be. You can also bump the compression considerably if you are using a larger cam. The LT1 383 in my 97 Camaro SS is 12.3:1 and runs on 93 octane. I'd have the stock heads ported, or go to some good aftermarket heads like the TrickFlows or AFR. The LT4 stuff isn't worth the money IMHO.
Old May 2, 2008 | 01:20 PM
94LT1VETTER's Avatar
94LT1VETTER
Even tho I'm having problems for now, I still like my 1.6 RR's. Like a mini cam swap but w/o all the hassle.
Old Jul 2, 2008 | 12:11 AM
MTVette's Avatar
MTVette
I took a 92 LT1 and rebuilt as a 383 stroker. Ported heads and intake, LT headers, etc etc. Runs 11's.
Old Jul 24, 2008 | 06:31 PM
BAM92's Avatar
BAM92
I took my 92 and put a full forged 383 with ported afr190's, full exhaust and a vortech pushing 12psi of boost. Just over 600 hp.
Old Aug 7, 2008 | 12:07 AM
Lichen's Avatar
Lichen
What he said, with a Hotcam and 1.6 RR. I gained 50 rwhp.
Old Oct 27, 2008 | 10:06 PM
larry00's Avatar
larry00
Most bang for the buck , K & N and cut out air box Quality Longtube Headers W/ x pipe and 3 in. exhaust
Everything else calls for megabucks and a low milage engine.
Old Nov 6, 2008 | 11:13 PM
96GS#007's Avatar
96GS#007
Determine your budget/what you're willing to spend and then determine your mods. Speed is merely a matter of money.
Old Nov 8, 2008 | 10:18 AM
Mr.Nubain's Avatar
Mr.Nubain
From: If you wanna live life on your own terms, you gotta be willing to crash and burn Florida
Agreed, I see this mod alot for the Camaro's and Trans Ams out there, they do this and add headers and next thing there in the 12's. The Hotcam/RR and Headers alot of HP for your buck.
Old Nov 11, 2008 | 10:13 AM
billla's Avatar
billla
St. Jude Donor '14
Exactly so; there are a lot of things you COULD do - budget determines what you CAN do.
To Lt1
