LT1 Heads/LT1 rebuild
Right now, I have the heads off and am preparing to have the head guy start grinding. I was wondering if anyone has sandwiched 2.05/2.08 intake vavles or 1.66 exhaust valves. Looking at the metal around the stock heads there doesn't seem much to play with. So what are the largest valve sizes anyone has put in?
Also what areas are you seeing the most from during a cleanup of the heads? Looking at the area machined for the pushrods, its seems that that area will reduce the ammount of material I can take off the insides of the runner.
Any specs that you can share would be appreciated.
Mike
Now am trying to find a good discount parts supplier to buy the goodies need to go with this setup. I notice Summit and Jegs have a pucity of LT1 components in their catalogs. Where do most of the folk on here go when they want high quality LT1 components.
Am looking at adding a Forged 3.75 crank; some 5.7 oliver, manley,lunati or summit H beam rods; JE 20cc dish pistons, child and alberts rings, and milodan 4 bolt splayed main caps on the lower end.
After Porting the heads will be looking at a 1.6 roller rockers, new valve springs, 2.02 in, 1.6 exhaust valves, and a @.50 480/480lift and about 230/230 duration. Hopefully this will go well with the supercharger.
On the injector side runng svo 30lbs. 58 mmTB.
I hope this combo should work well, haven't run all the numbers yet, and am open for suggestions on where to buy and how to change the combination for best performance. This will be attached to a 6 speed and a 3.73 rearend. Going for a strong 1/4 mile car and an occasional driver.
thanks for the advice
Mike
He can help you out on the head work too if you need. Good prices and service.
FWIW, if you are going to supercharge it, you will most likely need larger injectors than 30lb'ers. Maybe 36 or even larger depending on the timeframe and if you want to change injectors again when the blower goes on. You could probably find a better cam than what you listed too. A good blower cam usually has a longer duration on the exhaust as well. The Comp Cam 305 may be a better choice for all around. If you are looking strictly for drag racing and the occasional cruise, a 230/230, .480/.480 is pretty mild on the lift side for a hydraulic roller especially with 1.6 rockers and a 383 stroker.
Take a gander at this work and comment if you see any areas of improvement to his porting.
Bowl work (involved recontouring bowl and removing part of the ledge above the plug.)
intake work(gasket matched, removed some from lower part of runner and streamlined around valve seat)
exhaust work(gasket matched, except for lower portion of the D exhaust, some metal removed inside exhaust)
This is my mechanics first lt1 set of heads, he usually does F*rds and monster trucks, as well as ATV's and snowmobiles. So any comments would be appreciated.
Mike
[Modified by Mr Y Car, 10:28 PM 12/18/2001]
Te supercharged 383 LT1 is a fairly common buildup for the F-body and there is a ton of info on various parts combinations at the above mentioned site.
See ya,
John
[Modified by J Winkeler, 4:44 PM 12/19/2001]
Maybe i'm nuts ???? :crazy:
