Pushrods
Old Dec 14, 2001 | 01:14 AM
rainman69's Avatar
rainman69
Default Pushrods
Does this sound like any particular pushrod to y'all? I'm trying to determine the internals of my engine without too much pulling it apart.
7.75" length (in a 350 block)
Two types of metal (the ends are different, look at drawing for example)
Has oil hole through it.
Number on it is 48829.
Thanks! :smash:
[Modified by rainman69, 10:15 PM 12/13/2001]
Old Dec 15, 2001 | 03:30 AM
rainman69's Avatar
rainman69
Default Re: Pushrods (rainman69)
TTT.
Anyone, anyone...Bueller?
Old Dec 15, 2001 | 11:13 AM
clem zahrobsky's Avatar
clem zahrobsky
Cruise-In I Veteran
Cruise-In II Veteran
looks like a old TRW #
Old Dec 16, 2001 | 03:33 PM
JAKE's Avatar
JAKE
The length you posted seems a little short for a stock pushrod. Short by about .25. Most I've seen in the catalogs are closer to the 7.8 length.
Based on that part number, unless someone recognizes it, I guess all you can do is go to all the websites of the companies that sell pushrods and check.
Jake
Old Dec 16, 2001 | 05:02 PM
69bblock3x2's Avatar
69bblock3x2
Rainman,
48829 is an old TRW part number. It crosses to Sealed Power / Speed Pro # RP3212R. It should be a hardened chrome moly 5/16 dia. stock length rod.
Hope this helps.
John.
Old Dec 16, 2001 | 05:24 PM
rainman69's Avatar
rainman69
Default Re: Pushrods (69bblock3x2)
Thanks! I knew someone here would know. :smash:
To Pushrods
