85 computer switch to an 89
Old Dec 14, 2001 | 08:43 PM
Willycool's Avatar
Willycool
Default 85 computer switch to an 89
Hey everyone!
I would like to switch my 85 computer and wiring harness to an 89 computer and harness. I would like to know if anyone has attempted this and if so, can you offer my some advice.
Tx
Willycool :seeya
Old Dec 14, 2001 | 08:45 PM
JAKE's Avatar
JAKE
Default Re: 85 computer switch to an 89 (Willycool)
Yep; it very doable. There is a site that has all the step by step info you need, but I lost the URL when I installed a new harddrive.
Maybe someone will post it for you. If not check the archives.
Jake
Old Dec 14, 2001 | 09:11 PM
-=Jeff=-'s Avatar
-=Jeff=-
Default Re: 85 computer switch to an 89 (JAKE)
http://www.eecis.udel.edu/~davis/z28/ecm_swap/
Old Dec 15, 2001 | 03:56 PM
HighHopes85's Avatar
HighHopes85
I know this doesn't answer your question, but I was in the same shoes a couple of months ago.
Why are you doing this? I updated because I was pissed that Diacom didn't show much information that was useful when tuning. I was going to do the 85 to 89 update just like you.
Bowtye8 (Dennis) and Mojo (Chris) suggested that I go to the 90-92 Camaro ECM, which is identical to the 90-91 Corvette ECM so you can use a Corvette Calibration on it. I am glad they did, because I feel for my purposes, which including tuning my own chips, that this is the most worthwhile investment I have ever made. The price of the Burnoff and MAF relays you will need will be more than the price of a new MAP sensor, so if cost was prohibitive, this would offset it. Also, you need one more computer connector, which can be found at any junkyard for $2.00 in my case.
For details on this, go to http://forums.corvetteforum.com/zerothread?id=119460 It is read only, but I might end up starting up a new one if the ECM/PCM section ever gets started up here.
I know I didn't answer your question, but it all depends on what you want to do. Like I said, I would never ever ever go back!
:cheers: -Matt-
To 85 computer switch to an 89
