ZZ4 push rods
Old May 10, 2008 | 11:09 PM
John A. Marker's Avatar
John A. Marker
Default ZZ4 push rods
Discovered that the ZZ4 when using roller cam, and roller lifters uses a SHORTER pushrod . This combo uses 7.2" rods. Figure this into your future build if going to the ZZ4 or a roller block.
Oh yea, also used a different flexplate.
Old May 15, 2008 | 08:34 AM
rodj's Avatar
rodj
All the SBC roller cam engines (late L98 , LT1/4 , ZZ4 , Vortec ) have 7.2" pushrods v 7.8" for flat tappet cams.
All the above with one piece cranks have a flywheel / flexplate with 3.00" PCD crank pattern v 3.58' on the two piece seal cranks.
