Does anyone know if you can run an MSD 6AL box with these igniton systems? I don't know much about the ignition systems of these engines and haven't seen anyone using an MSD yet.
Thanks. :confused:
John, You probably would not see a gain unless you are having problems with the stock setup. The stock setup is very capable, but I run the ignition box mainly because of the Nitrous. I would be interested in seeing if you actaully get results from using one. Maybe I will do a test the next time I make it to the track. They are pretty easy to bypass for a run or two. Problem is I am not as consistent as you guys up there with your automatics ;). I use mine more for peace of mind than a gain.
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
Re: Lt1/Lt4 igniton and MSD (Vette92)
