GM HD timing chain set
Old Dec 28, 2001 | 05:00 AM
GlockLT4's Avatar
GlockLT4
Default GM HD timing chain set
How much stronger is the GM Heavy Duty timing set than stock? There's about a 400% price increase between the two
Old Dec 28, 2001 | 09:49 PM
mountainmotor's Avatar
mountainmotor
Default Re: GM HD timing chain set (Glock'94)
I think in your situation it is more like do I have to use that expensive cam chain used specifically with my hydraulic roller cam? The answer is yes unless you use an early front cover .Your builder should know this :)
Old Dec 31, 2001 | 01:30 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
I was using a stock chain in my 396. Looked new when it came out for the Cloyes.
Old Jan 5, 2002 | 05:19 AM
GlockLT4's Avatar
GlockLT4
Default Re: GM HD timing chain set (Vette92)
k.. sticking with the stock.. didn't think it would be a problem with the roller cam
To GM HD timing chain set
