Re: AFR 210's
Old Dec 30, 2001 | 04:08 AM
88-406's Avatar
88-406
St. Jude Donor '05
Default Re: AFR 210's
Anyone ever get them drilled for temp sensors? where there any issues?
KM
Old Dec 30, 2001 | 05:40 AM
ol,RJ's Avatar
ol,RJ
Default Re: AFR 210's (88-406)
I drilled and pipe tapped mine, no problem. they have plenty of thickness for it.
I did put the header on to make sure it would clear before drilling the hole.
one thing to remember is that a pipe tap gets bigger as you go in. so tap a little then check it with the sensor. you don't want the sensor to run out of threads before it gets tight. better to leave at least 3 or 4 threads showing on the sensor, so you have room to torque it down.
if your going to have it done by someone, bring them a sensor to check it with.
RJ
