LTX Shootout
Old Aug 5, 2008 | 11:56 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Default LTX Shootout
I got to hit this next year
http://www.gmhightechperformance.com...age/index.html
Jeff Green swapped out his Opti in under two hours after the rotor pin let go to qualify, but was only able to coast to an 11.20 after the transmission let go-way off his best of 9.50 at 150 mph. Unknown to Jeff at the time, the cam pin had also sheared, which probably resulted in the wheelhop that broke the trans and bent the rear sway bar. If you're wondering, that's not silver paint on that block, it's a 446ci aluminum Donovan that's been welded and milled into the shape of an LT1 block, making 1,300 horses with the factory OBD-I PCM! Jeff has kept this 4,400-pound beast as stock as possible and even runs the original 10-bolt rear housing. We will go into detail on this amazing car in an upcoming feature.
Old Sep 10, 2008 | 12:00 PM
5abivt's Avatar
5abivt
details on that block would be amazing.
Old Sep 10, 2008 | 04:56 PM
MarkBychowski's Avatar
MarkBychowski
I would risk a criminal record to steal his car just to get the block!
Old Sep 11, 2008 | 09:52 PM
BrianCunningham
I've seen some threads on the camaro boards but...
Old Oct 3, 2008 | 10:37 PM
BrianCunningham
I managed to find this old photo
To LTX Shootout
