Can this block be repaired?
Old Sep 3, 2008 | 03:03 PM
sharkskin69's Avatar
sharkskin69
Default Can this block be repaired?
I am a newbie and am restoring/rebuilding a 69 Corvette to show and drive. The engine block is cracked. I found a machine shop in New England that says they can metal stitch the block. I was wondering if anyone had any experience with this kind of repair or is there a better way? It is the original 427 390HP block and I would like to save it if possible, But I want to drive this car when finished and I don't want spend the $$ rebuilding the engine if this repair is going to come back to haunt me in the future.The machine shop is J&M Machine www.jandm-machine.com Does anyone have any experience with them or could you recommend anyone else? I am in the Philadelphia area. The block has two cracks. One is easy to see the other a little more difficult. I marked the block with tape in the one picture so you could see where the crack is. Any input would be appreciated especially from those in the know.
Thanks, Tony
Old Sep 6, 2008 | 06:50 PM
John A. Marker's Avatar
John A. Marker
I would think it was possible. It is in the water jacket and not the cylinder so there is not a lot of pressure. Cast iron CAN be welded, but it takes experience and special rod to do it correct.
Will they guarantee their work??
Old Sep 7, 2008 | 10:29 AM
StrokeThis's Avatar
StrokeThis
1st Gear
i have repaired blocks and heads with the stitch method with both good and bad results.
the crack on the outside of the block looks like a good candidate for "stitching" but its awfully close to the head bolt hole. that may cause a problem down the road.
if you can find a shop that has extensive experience with cast iron welding you are better off. it will cost you but if something like barret jackson is your goal....?
there is also something called "spray welding" using a torch and a filler powder. i have no experience with it but saw a demonstration at a welding shop open house that blew my mind.
good luck.
Old Sep 9, 2008 | 01:31 AM
gkull's Avatar
gkull
I would not even dork with it. Who's to say that motor was original anyway? The 390/427's were a toad when they were brand new in 69. Throw it off in the corner and put a fun motor in it. Then when you sell the 69 tell them that you have the original???????? and let some poor sap deal with it.
Vettes are small peanuts in comparison to real collector cars. Smart people research old race cars and restore them. The profit margin is so much greater.
Like this March F2 I'm working on. You buy a basket case for $15K and you put about $30-40K into it and 100's of your free man hours and you end up with a $150 - 175K Or like the next level buy a basket case Lola Ford IMSA car for $150K and put $200K more into it and 100's of free man hours and you have a nearly a million dollar car.
Old Sep 10, 2008 | 03:06 PM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
Default Trash it.
George is right. That block was frozen with water in it and may have unseen hidden damage inside. I can see more cracks in the lifter valley above the lifter bores just from your pix. Save our hobby from futility, cut that block in half or at least grind off off the casting numbers - grind off the ID stamp pad too.
cardo0
To Can this block be repaired?
