How to build power?
Old Jan 6, 2002 | 11:57 PM
JackCooper's Avatar
JackCooper
Default How to build power?
I'm wanting to build a 350 to about 400 horsepower as cheaply as possible.
Any suggestions?
Old Jan 7, 2002 | 02:22 AM
BlackRocket's Avatar
BlackRocket
Default Re: How to build power? (JackCooper)
The right heads and cam will give you 400 HP. All you need is a good breathing 350 to get there. Torque is another story; (Stroke). But, HP is a function of torque and RPM. Depending on what you want to spend, I would probably try to go with a 383 motor, but you can do a top-end only package for a lot less. The most "Bang for the Buck" is a top-end package, but if you have to do a complete rebuild, you might as well as go to a 383 and add a roller valve-train for smootheness and longetivity. :D
Old Jan 7, 2002 | 02:51 AM
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
Default Re: How to build power? (BlackRocket)
Depending on what motor you are starting out with and your goals a crate motors can be a good deal. http://www.sallee-chevrolet.com/sales.html has some good packages.
[Modified by 93Polo, 1:52 AM 1/7/2002]
Old Jan 7, 2002 | 10:09 PM
korvetkeith's Avatar
korvetkeith
Default Re: How to build power? (93Polo)
Vortec heads! :chevy
To How to build power?
