Lt1 motor has dead spot
Old Sep 28, 2008 | 04:15 AM
Gary Huller's Avatar
Gary Huller
3rd Gear
Default Lt1 motor has dead spot
Hello,I was hoping for some info.I have a 1984 with a 91 Lt1 motor.It used to run great but now it misses.I;ve replaced all the sensors.When you give it gas it will stall if you push on the pedal fast.Sounds like knocking.It also smells like it is burning to rich.Could the older fuel pump have gotten weak and it isn't pushing enough p.s.i.? Gary
Old Sep 28, 2008 | 11:39 AM
cv67's Avatar
cv67
St. Jude Donor '05
If it smells rich ohm your injectors.
Sure its a LT1? They didnt come out til 92
Old Sep 28, 2008 | 10:40 PM
sly vette's Avatar
sly vette
Knocking????? Poss. pre-ignition???
Old Sep 28, 2008 | 10:46 PM
Gary Huller
3rd Gear
I don't mean to sound dumb but don't know what ohm the injectors,means.Would it tell me in a corvette book like,Chilton? Gary
Old Sep 28, 2008 | 10:59 PM
Gary Huller
3rd Gear
If I give you the vin number of the car the motor I thought was an LT1,could you tell me if it is a 91 ,5.7 literand what do you call it? If not an Lt1. Gary
Old Sep 28, 2008 | 11:28 PM
cv67's Avatar
cv67
St. Jude Donor '05
more than likely it is the "L98" TPI that came in 85-91. intake looks like a spider so to speak, 2 curved intake runners per side. Sound right?
To Lt1 motor has dead spot
