L88 air cleaner drop dimension?
Old Jan 8, 2002 | 05:47 PM
Marks69BB's Avatar
Marks69BB
Default L88 air cleaner drop dimension?
Continuing to work on the airbox conversion and am looking at the L88 air cleaner drop base from Zip; $89 - I don't think so! Anyone tell me what the amount of drop in inches is on theirs so I can hunt aftermarket ones?
Old Jan 8, 2002 | 08:16 PM
ML67's Avatar
ML67
Default Re: L88 air cleaner drop dimension? (Marks69BB)
2"
Old Jan 8, 2002 | 09:43 PM
Flareside's Avatar
Flareside
Does the $89 price include everything? I actually though it would be more like $200 with the spark arrestor screen, etc.
Old Jan 9, 2002 | 03:11 AM
Les's Avatar
Les
Mark,
If I'm reading this right you're asking about the air cleaner base that the foam ring will rest on to seal w/ the airbox. If so, I used the stock base that came w/ my L36 & it fits perfectly. Maybe you can hunt down one of those for less.
Old Jan 9, 2002 | 01:08 PM
Marks69BB's Avatar
Marks69BB
Default Re: L88 air cleaner drop dimension? (Les)
Thanks guys - The $89 is for the drop base only from ZIP. Before I got the airbox, I had the non-funct L88 hood with an aftermarket 3"x14" aircleaner with drop base which I'll have to measure when I get home from work. The AL hi-rise GM rect port intake on my engine was used on the 71/72 454 Camaros with the ram air so I'm not sure how it compares in height with the L88, L36, or other aftermarket intakes. I'll use the 2" as a reference to figure out what drop base I'll need to get within 1"-1.5" of the bottom of the airbox.
Can't beat the forum for info! :cheers:
To L88 air cleaner drop dimension?
