I have a zz4 with lt4 hot cam and 1.6 rockers
I am looking for some heads that will work good on the street
Looking at the AFR 180 eleminators and GM fast burns
Which of these would be the best on the street
How much HP and torque might these combos make
I am really looking for some more HP and torque
Which one of these heads would be best for street use
I would not know who to trust to port heads around here
Well, as a general guideline for a 350 CID engine intake runners around 170-180 CFM are the best fit - you could go as far as 195's with the Hot Cam's .525 lift (with 1.6 rockers)
The Fast Burn heads (GMPP P/N 12464298) are 210cc intake runners, which IMHO is too big for a street 350 with a relatively mild cam like the Hot Cam.
So, I would lean towards a 180-195cc intake runner head. AFR 180's are a great choice; I would lean towards the Streets vs. Competitions or Eliminators myself.
The problem you face is that your existing heads are 58cc combustion chambers, and both of the heads you're looking at are 64cc - so you're losing about .7 points of CR with the swap.
I'd estimate about a 40HP/30TQ gain from the swap. In terms of gain/$, not sure that it would be worth the swap. There are plenty of porting companies that would massage those L98's for you.
AFR 180 is a great choice. It takes an awful lot of work to get the L98 head in the 250 range and even then you still have a 18+ yr old head
Not worth it.
AFR 180s. Lot's of magazine tests with these heads post some pretty impressive HP and torque numbers. You can port L98 heads and not get near the flow numbers AFRs make. Let's say you can find L98 heads for $200, send them to DR-Js for a $900 port job and you still won't have heads that will flow like the AFRs. Spend $340 more and be happy!
From: Las Vegas - Just stop perpetuating myths please.
Save your breath folks.
How did you put a GEN II cam in a GEN I block without a cam retainer plate on the front of block? What did u do with the long dowel pin on the end of the LT4 cam that turns the opti dist?
cardo0
I don't think GM's Hot cam he is using is actually for a LT4. It may be same profile though. ZZ4 does use LT4 valves, springs, and retainers in the L98 heads, I do believe.
But then again, I do remember a hole in the front of the cam that may have been for a dowel in LT4 application - and ZZ4 does use a cam retainer.......
